Largest Tire on a stock RT Rim - Dodge Magnum Forum - Modern Mopar Forum
Go Back   Dodge Magnum Forum - Modern Mopar Forum > Dodge Magnum Forum - Custom Dodge Magnum Performance and Mods Zone - Custom Dodge Magnum Mods! > Dodge Magnum Custom Chassis - Suspension
Old 08-15-2019, 06:03 PM
RTaylor RTaylor is offline
RTaylor is on a distinguished road
Default Largest Tire on a stock RT Rim
Hello guys, Can someone tell me the biggest tire you can install on a stock RT rim? My 2006 has the 18 inch wheels and I will be getting new rubber soon and want to go with a little wider type tire but I do not want any fitment issues your help is greatly appreciated.
Old 08-22-2019, 08:23 PM
GeoffM's Avatar
GeoffM GeoffM is offline
GeoffM is on a distinguished road
Stock I believe is 225/60R18 I think the largest you an get on those rims is 255/50R (10" tread) should fit on a 7" rim 305/45R18 thats 12" of tread probably need a 9" rim, I have AWD with 7.5 in rims - keeps your tire diameter correct for your speedometer.
I'm so two thousand and eight....You so two thousand and late.....I got that boom, boom, boom
Old 08-23-2019, 01:12 PM
HemiLonestar's Avatar
HemiLonestar HemiLonestar is offline
HemiLonestar is on a distinguished road
225 is the stock width that comes with it, wouldn't go over 245 on a 7.5" wide rim (I ran Falken Ziex 950 245/50's on my 18's) otherwise sidewall bulge is horrific and you negate the extra tire width since it's curling up. Assuming you have RWD any year 20x8 will bolt right on and you can step up to a 255 without issue (what I have on mine)...
05 Magnum R/T, 12 Charger SRT, 03 Hemi Ram
Old 08-23-2019, 01:29 PM
When changing from 18 in wheels to 20s don't you have to re calibrate the Speedo?
Old 09-12-2019, 06:56 PM
HIPCHIP HIPCHIP is offline
HIPCHIP is on a distinguished road
I'm running 255/55R18's on mine. Tire store said that it was the biggest I could fit if I remember correctly. It is a nice WIDE size. Last time I got new tires the shop said "THOSE ARE BIG!" My car is a 2005 R/T and I have been running that size with no problems since the first tire change at 20K miles.
08 SXT stock rim size 2wheel Dodge Magnum Custom Chassis - Suspension 0 05-02-2014 11:02 PM
Tire Kingdome ruins two of my 22" rims!!! NOTPAID4 Other Vehicle Discussion 6 01-23-2011 07:32 PM
22 's OPTION 5 what tire's Dutch Dodge Magnum General Discussion 4 11-18-2010 11:00 AM
tire size tannkgirrl Dodge Magnum General Discussion 7 09-23-2010 12:07 PM
